Quick question really:
Is there any issue with deleting TM1 log files using wilcardfilesearch in a TI process?
Or is it better to use the executecommand function to call a script?
Ti to delete Log files best practice
- Elessar
- OLAP Product: PA 2
- Version: 2.0.9
Re: Ti to delete Log files best practice
IBM recommends cmd: http://www-01.ibm.com/support/docview.w ... wg21903675
I prefer to use the Bedrock process: https://github.com/cubewise-code/bedroc ... Delete.pro
TM1 and Data Science blog: 6th article - PAfE + VBA: Commit each cell without pressing “Commit” button.
- Alan Kirk
Just that you need to be powerfully careful about how you define your search.
IMHO the best practice is DON'T. I zip those suckers up mercilessly with 7 Zip but I don't look at deleting any transaction logs for literally years.
However if you are bound and determined, I would recommend just tapping into the Bedrock library; specifically Bedrock.Server.LogFile.Delete. The code has already been checked and it allows you to optionally eliminate a range of other files as well. It also gives you control over the date range deleted.
- Version: 10.1.1
- Excel Version: Excel 2010
Thanks for the feedback, will have a look at the bedrock process.
Haven't really acquainted myself with any of the bedrock processes, which on one level is good because I have tried to solve problems myself, albeit with help from the experts on here now and again! On another level it may be bad because a little knowledge can be dangerous!
I have written a TI using wildcardfilesearch which works and is in the test environment but I googled just to check there were no issues I hadn't thought of before deploying to live and the advice was shut the server down before deleting any log files etc. So that prompted me to post here!
