I am facing some problem using suppress zero on TM1.
I have some calculated fields, but when I suppress zero the system ignore this fields and nothing more appears (even with numbers calculated).
And in this example I am on N-level. So it is not a feeder problem.
Anybody have see this already?
Thank you,
JR
Suppress Zero
- Version: 10.2
- Excel Version: 2013
- Version: PAL 2.0.9.18
Re: Suppress Zero
Why not ?Jorge Rachid wrote:And in this example I am on N-level. So it is not a feeder problem.
IBM Champion 2024
IBM Champion 2024
- Version: 10.2
Re: Suppress Zero
Because I am on level N.
If there is not a total at my view it shouldn't suppress zero, or not?
Thank you,
JR
Thank you,
JR
- Alan Kirk
Re: Suppress Zero
Wim Gielis wrote:Why not ?Jorge Rachid wrote:And in this example I am on N-level. So it is not a feeder problem.
I think the point that Wim was trying to subtly make is this:Jorge Rachid wrote:Because I am on level N.
"You know that idea you have that unfed cells only affect consolidations when zero suppression is on? Yeah, that one. Get rid of it."
If you zero suppress on an unfed, rule calculated, completely N level cell when you have skipcheck on... yes, it is possible that the value will not appear.
Therefore the solution is to turn off zero suppression, right click on the cell and select Check Feeders. Odds are that you will see those two magic words "Not Fed". If so, fix your feeders and try calculating again with zero suppression on.
- Version: 10.2
Re: Suppress Zero
Now I understood.
Thanks for helping again.
JR
JR
