So here's the situation - we have 2 x services on one server:
Server = APAUSTMC01
Services = FinUAT1, tm1_dev
When logging in via TM1WEB, you of course have to choose the Service that you wish to login to.
Despite choosing only 1 service at the login, when we use TM1 formulas in a Websheet, it consistently detects us as being logged into BOTH services on that server.
e.g. we used the TM1USER, DIMIX, DBRW etc formulas to test this - and they were able to retrieve data from both services at once
Has anyone else had a similar issue with this? Any known workarounds...?
Thanks!
Formulas in TM1WEB
- Version: PAL 2.0.9.18
Re: Formulas in TM1WEB
Are you still on TM1 9.5.2, as mentioned in your profile ?
Or in what version do you see this behaviour ?
IBM Champion 2024
IBM Champion 2024
This is a "feature" of TM1 Web and it can be quite a useful one as you can actually combine several TM1 instances into a single application workflow. What happens in the background is that if the websheet has any references to another TM1 instance the user's credentials are checked, if the username & password is a match between the instances then the user the logged on automatically in the background to the 2nd instance and the data is retrieved. This only works for instances on the same admin host and having the same authentication method.fleaster wrote:Despite choosing only 1 service at the login, when we use TM1 formulas in a Websheet, it consistently detects us as being logged into BOTH services on that server.
If you want to avoid this as opposed to take advantage of it.
- don't reference a 2nd instance in the websheet (this includes not using the tm1user trick to dynamically assign server)
- point the instances to separate admin hosts
- have different security authentication between the instances, e.g. one with CAM, one with native
- Excel Version: XL2010
thanks for the feedback - I just read similar on the IBM website http://www-01.ibm.com/support/docview.w ... wg21959813
P.S. I'm on v10.2.2, just hadn't updated my profile in quite a while
...I guess we'll just have to work around this (or take advantage of it!)If TM1Web is connected to a TM1 Admin Server with both the development and production TM1 models, both TM1USER functions will return a value.
