SubsetElementInsert - all items under roll up
- OLAP Product: Cognos
- Version: Planning Analytics 2.0.7
I'm using a SubsetElementInsert in a TI process that creates source view for data transfer.
For example: SubsetElementInsert(vDimName,sSubset,'(P&L)',1); where P&L represents a roll up of profit and loss GL accounts.
However what I actually want is to list all the level 0 items under "(P&L)" instead of the rollup.
How should I code this?
Thanks in advance.
Kenneth
Thanks in advance.
Kenneth
- gtonkin
Re: SubsetElementInsert - all items under roll up
You would probably want to do this via MDX e.g.
sMDX='{TM1FILTERBYLEVEL( {TM1DRILLDOWNMEMBER( [<dim>].[(P&L)]}}, ALL, RECURSIVE )}, 0)}';
SubsetCreateByMDX(sSubset,sMdx);
Unfortunately I got an error saying Syntax error at or near: "}, ALL, RECURSIVE )}, 0)}", character position 65 expression.
Below is how the view and subset are setup.
Moreover, I realize that in addition to N02PNL I also need to include N02BUD. Should I create sMDX2?
Many thanks.
Many thanks.
IF (vDimName @= 'FINDW_Business_Unit');
SubsetElementInsert(vDimName,sSubset,'(ROY1+ROY2)',1);
ELSEIF( vDimName @= 'FINDW_Account');
sMDX='{TM1FILTERBYLEVEL( {TM1DRILLDOWNMEMBER( [FINDW_Account].[N02PNL])}, ALL, RECURSIVE )}, 0)}';
# Creates all N level elements within each dimension (default case)
ELSE;
vIndex = 1;
vIndexSub = 1;
WHILE(vIndex <= DIMSIZ(vDimName));
vElement = DIMNM(vDimName, vIndex);
IF(DTYPE(vDimName, vElement)@='N');
SubsetElementInsert(vDimName, sSubset,vElement, vIndexSub);
vIndexSub = vIndexSub +1;
ENDIF;
vIndex = vIndex + 1;
END;
ENDIF;
- gtonkin
You can specify multiple items as a set and then drill them down.
Not always easy to get the syntax correct when you are typing straight into the forum but try this:
sMDX='{TM1FILTERBYLEVEL( {TM1DRILLDOWNMEMBER( {[FINDW_Account].[N02PNL],[FINDW_Account].[N02BUD]}, ALL, RECURSIVE )}, 0)}';
Unfortunately this time I've got into "Unable to register subset" error.
I began with the section with SubsetCreate (vDimName, sSubset) and add dimensions one by one using IF and ElseIf, maybe that's my problem and the dimension using MDX be treated separately?
I don't know...
I don't know...
- gtonkin
Make sure you cleanup temporary subsets-one probably exists and will need to be destroyed before creating via MDX
It's clean. All temp. view and subsets are empty.
I don't know. Will take a break and revisit it.
Thanks!
Kenneth
Thanks!
Kenneth
- PavoGa
- Excel Version: 2013 PAW
Just a hint to make the code a little cleaner to view: the functions that return a set do not require the {} to work properly. The {} are redundant. Only around members are those required in order to return a set when a set is needed.
For instance:
Works as well as:
With regards to the code that is failing:
Here is the correction:
The {} needed to surround [FINDW_Account] and the first ) after [N02PNL] was removed. Hope this solves it for you.
For instance:
TM1FILTERBYLEVEL( TM1DRILLDOWNMEMBER( {[FINDW_Account].[N02PNL],[FINDW_Account].[N02BUD]}, ALL, RECURSIVE ), 0)
sMDX='TM1FILTERBYLEVEL( TM1DRILLDOWNMEMBER( {[FINDW_Account].[N02PNL]}, ALL, RECURSIVE), 0)';
Ty
Cleveland, TN
Cleveland, TN
Thanks, the line works. But I still can't register the subset. After some testing I realize
SubsetCreateByMDX(sSubset, sMDX);
doesn't work when it being placed in a sequence of creating subset for each dimension in the cube to create a source view.
I tried using sSubset1 but not being able to assign it to the source view.
BTW, temporary view and subsets are all deleted before testing.
Still trying to get around it.
But thanks!
Kenneth
But thanks!
Kenneth
# cube info
sCube = 'FINDW_Ledger';
sSubset = 'source_transfer_ledger_to_obm_actuals_subset';
sView = 'source_transfer_ledger_to_obm_view';
#Recreate the Source View
IF(ViewExists(sCube, sView) = 1);
ViewDestroy(sCube,sView);
ENDIF;
ViewCreate(sCube, sView);
vSOldLogChanges = CubeGetLogChanges(sCube);
vTOldLogChanges = CubeGetLogChanges(tCube);
CubeSetLogChanges(sCube, 0);
CubeSetLogChanges(tCube, 0);
######## Create other subsets and Source View#########
vIndexDim = 1;
WHILE(TABDIM(sCube, vIndexDim) @<> '');
vDimName = TABDIM(sCube, vIndexDim);
#Subset Creation
IF(SubsetExists(vDimName, sSubset) = 1);
# if the subset already exists, destroy it for creation later
SubsetDestroy(vDimName,sSubset);
ENDIF;
# Create and add elements
SubsetCreate(vDimName, sSubset);
# Adding boundaries onto subsets
IF (vDimName @= 'FINDW_Account');
sMDX='{TM1FILTERBYLEVEL( TM1DRILLDOWNMEMBER( {[FINDW_Account].[N02PNL], [FINDW_Account].[N02BUD]}, ALL,
RECURSIVE), 0)}';
#Creates all N level elements within each dimension (default case)
ELSE;
vIndex = 1;
vIndexSub = 1;
ENDIF;
END;
ENDIF;
ViewSubsetAssign(sCube, sView, vDimName, sSubset);
vIndexDim = vIndexDim +1;
END;
- Version: PAL 2.0.9.18
If you do SubsetCreate in the code followed by SubsetCreateByMDX (on the same dimension and subset), it will fail.
IBM Champion 2024
IBM Champion 2024
Revised coding:
However, if you are unfamiliar with writing TI code, please consider Bedrock.
Also, adding dimensions at N-level is not needed strictly speaking, so the loop could be greatly simplified and even removed.
# cube info
vIndexDim = 1;
sMDX = '{TM1FILTERBYLEVEL( TM1DRILLDOWNMEMBER( {[' | vDimName | '].[N02PNL], [' | vDimName | '].[N02BUD]}, ALL, RECURSIVE), 0)}';
ELSE;
sMDX = '{TM1FILTERBYLEVEL( TM1SUBSETALL( [' | vDimName | ']), 0)}';
ENDIF;
vIndexDim = vIndexDim + 1;
END;
IBM Champion 2024
IBM Champion 2024
Dear Wim,
Thanks for the revised code.
Can I ask a simple question?
Does it mean that if I'm using MDX in a loop to add subsets, I should use MDX for other dimensions (if I want to add specific group) as well instead of subsetelementinsert?
Kenneth
Kenneth
You can decide subset by subset if you use SubsetCreateByMDX or SubsetCreate/SubsetElementInsert.
IBM Champion 2024
IBM Champion 2024
OK. I'll trying implementing it.
Thanks!
Thanks!
Hi Wim,
I started working on it yesterday and yes it's working now!
Thanks a lot!
Kenneth
Thanks a lot!
Kenneth
Good news, well done !kenship wrote:Hi Wim,
Thanks a lot!
Kenneth
IBM Champion 2024
IBM Champion 2024
