Within TM1 applications is it only Admin that can reset the state of all nodes to available ?
I have a couple of users who would like to be able to action this themselves.
Thanks in advance.
Status reset in TM1 applications
- LeeTaylor1979
- OLAP Product: tm1
- Version: 10 2 2 - 2.0.5
Re: Status reset in TM1 applications
I have not used Contributor for a while but is there a reset button on the portal? Do I remember well? If so, run it, and then check in the tm1server.log which TI was executed. Then give access to that TI for the user group you wish
- Elessar
- OLAP Product: PA 2
- Version: 2.0.9
LeeTaylor1979,
Yes, by default only admin can reset applications.
You can create a process, which will reset an application using tm1 application maintenance utility
TM1 and Data Science blog: 6th article - PAfE + VBA: Commit each cell without pressing “Commit” button.
