I am trying to set a global homepage in TM1 Web and using the below:
<add key="HomePageObject" value="\\TM1Server\D$\TM1\TM1_Instance\DATA\}Externals\01NetPay.xlsx_20160610012458.xlsx;Type=websheet;Description=My Uploaded websheet;AllowOverwrite=false" />
When I login in TM1 web, the home page is blank white.
Can someone advise me on what I am doing wrong?
TM1 Web Global Homepage
- gtonkin
Re: TM1 Web Global Homepage
Looks like you are missing the "TM1:" in front of your websheet reference. Your slashes also look to be back, not forward.
Have a look here for some guidance (10.2.2 reference)
Generally it is much easier (and more flexible) to write a rule in the }ClientSettings cube.
- Version: 10.1.1
- Excel Version: Excel 2010
I tend to use the Client setting for this, but I don't use a rule. I just Ctrl C and Ctrl V when a new client is added!
So under Web Home Page Object I would put something like, TM1: //TM1Instance/blob/PUBLIC/.\}Externals\Main Menu.xlsx, against the Client.
I would be interested to know how the rule would work, would it say something like (not written in rule syntax),
If client group is X then
Web Home Page Object = TM1: //TM1Instance/blob/PUBLIC/.\}Externals\X Main Menu.xlsx
else
Web Home Page Object = TM1: //TM1Instance/blob/PUBLIC/.\}Externals\Y Main Menu.xlsx
else
Something like that. Usually I have 1 or 2 "default users" set up where the home page object link is entered. These users are stet and then all other users link with DB() to the default user(s)Mark RMBC wrote:I would be interested to know how the rule would work, would it say something like (not written in rule syntax),
else
- Version: Planning Analytics
Thank yougtonkin wrote:Looks like you are missing the "TM1:" in front of your websheet reference. Your slashes also look to be back, not forward.
Thank you everyone, the above resolved the problem.
