Hi guys!
Probably everyone of you faced with the locks problems in TM1. I need an advice.
We have TM1 model with TI process which called by user and it takes 10 - 15 min.
In parallel with this process, users try open views and read data. I made reservation on all cubes (so, users can't realize write locks).
But process realize locks on many object of the system and users wait this. But when process done and try to commit changes, users breakthrough with opening of views, and process rollback and not commit changes. I don't understand the logic. Why users wait 15 min, and after that (when process done) crash sequence of the process and push it to rollback even if they can't write anything.
I try to use BulkLoadMode to decide this, but at this case I can't stop process by TM1TOP. May be you have little API application with disabling of BulkLoadMode, or may be you have any other solution of this problem.
BulkLoadMode. TI RollBack problems
babytiger
- OLAP Product: Cognos TM1, EP, Analyst
- Excel Version: 2013
Re: BulkLoadMode. TI RollBack problems
Trying to understand your issue.....
- user executes a process (takes a while to complete), what type of updates is this TI doing? Mainly cube data, or does it involve dimension updates as well?
- other users trying to access views of this cube...but had to wait for the above TI to finish.
- process completed, but roll back? and didn't commit changes? didn't understand this one.
- server crashes as result?
- parallel interaction
- does the above TI needs 10-15 minutes of processing time, can it be done quicker
- or use of sandboxing for data commit, etc.
MK
- Elessar
- OLAP Product: PA 2
- Version: 2.0.9
Nikita, what version of TM1 are you using?
I faced the same in 9.5.2: users' activity forced the process to rollback, and I needed to turn on bulkload. In 10.2.2 we didn't face any rollback problems.
- nlashin
- Excel Version: 365
This process interact with Cube A. User try to open view in Cube B. Cube B depend on Cube A. But user haven't got permissions to change something (reserve on a cube), only can read data.babytiger wrote:[*]user executes a process (takes a while to complete), what type of updates is this TI doing? Mainly cube data, or does it involve dimension updates as well
Users had to wait for the TI to finish when try to open view in cube B.babytiger wrote: [*]other users trying to access views of this cube...but had to wait for the above TI to finish.
When process complete, it unlock objects (as i understand), but not commit changes yet. And when unlocking happens, user's view (which was in waiting phase) start building and it cause that process rollback and start again. In this case i have a question. Why user wait whole ti process duration to open view, open it at the end and push process start again.babytiger wrote: [*]process completed, but roll back? and didn't commit changes? didn't understand this one.
Nobabytiger wrote: [*]server crashes as result?
Unfortunately, nobabytiger wrote: [*]does the above TI needs 10-15 minutes of processing time, can it be done quicker
Interesting your experience to use this to prevent process rollback. Is it online synchronization between sandbox and base data?babytiger wrote: [*]or use of sandboxing for data commit, etc.
- nlashin
Hi, Elessar!Elessar wrote:Nikita, what version of TM1 are you using?
Do you use parallel interactions in 10.2.2 model?
- nlashin
And very interesting how you stop your procedures in bulk load mode?Elessar wrote: I faced the same in 9.5.2: users' activity forced the process to rollback, and I needed to turn on bulkload.
ByronB
- OLAP Product: TM1 + BI
- Version: TM1 10.2
- Excel Version: Excel 2010
Hi nlashin,
You should definitely use Parallel processing in order to speed up your TI. If your TI copy a full year data from Cube A to cube B, instead of using one TI to copy the full year, you could run 12 TI, one TI load one month, it will run 12 times faster
Parallel processing works very well with TM1 10.2.2. The only issue I've seen is if you use TM1 + CAM security and for CAM Security you use Cognos BI Runtime. If you use Cognos BI Runtime, you should upgrade to Cognos BI
Parallel processing with TM1 + CAM security works very well if you use Cognos BI for security
If you want to use parallel processing, I highly recommend to use Hustle, it is a free tool that will help you to manage treads
http://cubewise.com/blog/hustle-tm1-uti ... nload-free
- nlashin
ByronB, Hi!
Sounds great, thanks! I'll try this and then give you feedback then!
- Elessar
- Version: 2.0.9
Yesnlashin wrote:Do you use parallel interactions in 10.2.2 model?
No one can disturb a process in bulk load modenlashin wrote:And very interesting how you stop your procedures in bulk load mode?
