Decimal precision
Decimal precision
Hi ,
Environment - Cognos TM1 10.2
I have a rule calculated cell which is calculating to = - 0.0000000000000345
TM1 has limitations with the no of decimal values it takes. Hence, TM1 is storing this value as -0.000000000
As minus zero does not make any sense and while exporting the value. It is treating this value as Zero (0).
Can you please suggest to round up "- 0.0000000000000345" the calculated value instead of showing "-0.000000000".
Vinay
Vinay
Re: Decimal precision
Ever heard of ROUND and ROUNDP?
Thanks for the reply Tomok...
As i require the value till 9 precision. Hence, Round is not suitable.
ROUNDP function is not working beyond 9 decimal precisions to display or extract the value
ex -
ROUNDP(- 0.0000000000000345,10) = (0.000000000)
Let me know if i am missing any thing.
ex -
I trust you are not working with accounting data
Depending on your rule (which you haven't posted) you might get somewhere by scaling up the intermediate results into a range which TM1 can work with - assuming that your results don't go up to the high end of the range as well.
- Version: 10.2.1.1
- Excel Version: 14.0.6129.5000
Apologies if this is not entirley relevant but..
as far as I am aware, TM1 stores data as the value type of Double...can anyone confirm this?
Thanks.
Thanks.
- qml
- Excel Version: 2007 - 2016
https://www-304.ibm.com/support/docview ... wg21515228TrevorGoss wrote:as far as I am aware, TM1 stores data as the value type of Double...can anyone confirm this?
The below section is relevant to both your question and the OP's question.
TM1 Precision
Technote (FAQ)
Question
What is the decimal precision of TM1?
Answer
TM1 stores data in IEEE-754 Floating Point Double.
The maximum number of digits is 15+ (almost 16, but some 16 digit number will not fit with full precision).
TM1 will clip to 14 digits for display.
By default Architect will display 9 digits of precision after the decimal point. This can be modified by by defining a custom format for the cell. Of course, the same overall 15 digit limit still applies. If one has 10 digits to the left of the decimal point, there will be only 5 digits to the right.
Kamil Arendt
- Version: 10.2.1.1
Just what I was looking for, thank you.
- Version: 10.2
Someone will correct me if I'm wrong, but wouldn't TM1 be able to handle small numbers by using E-20 type stuff. For example 0.0000000000000345 would actually be 3.45E-14, therefore there should be no limit to the size of a number, large or small, only the precision.
In the example given by the OP, I would think it can be solved with formatting - ie use a scientific formatting that outputs 3.45E-14 as most other systems will interpret this correctly.
This is all assumptions and speculation on my part, so I would be interested if anyone can back this up.
- Version: 10.2
To provide more on my point, the following rule works, and evaluates ['Gross Revenue'] as 2.
['Existing Stores Revenue'] = N: 1 / 1E20;
['New Stores revenue'] = N: ['Existing Stores Revenue'] * 2;
['Gross Revenue'] = N: ['New Stores revenue'] * 1E20;
- qml
You are not wrong. Quite the opposite, you are right. The limitation is in how many significant figures of a number TM1 can store and handle. You can do a simple test and type into any numeric cell the following value:whitej_d wrote:there should be no limit to the size of a number, large or small, only the precision.
12345678901234567890123456789012345678901234567890 (50 digits)
and TM1 will happily store it, but will display it in CubeViewer as:
12345678901234000000000000000000000000000000000000 (50 digits, but truncated after the 14th significant figure)
and internally it will in fact be stored with a slightly larger precision:
12345678901234560000000000000000000000000000000000 (50 digits, but truncated after the 16th significant figure).
Kamil Arendt
- Version: 9.5.2 10.1 10.2
- Excel Version: 2003 2007
TM1 uses IEEE754 double precision for its numbers (explained here http://en.wikipedia.org/wiki/Double-pre ... int_format) and that format does have limits, if you can call them that.whitej_d wrote:there should be no limit to the size of a number, large or small, only the precision
From that page ...
0000 0000 0000 000116 = 2^(−1022−52) = 2−1074 ≈ 4.9406564584124654 × 10^−324 (Min subnormal positive double)
000f ffff ffff ffff16 = 2^−1022 − 2^(−1022−52) ≈ 2.2250738585072009 × 10^−308 (Max subnormal double)
0010 0000 0000 000016 = 2^−1022 ≈ 2.2250738585072014 × 10^−308 (Min normal positive double)
7fef ffff ffff ffff16 = (1 + (1 − 2^−52)) × 2^1023 ≈ 1.7976931348623157 × 10^308 (Max Double)
Thanks all !!
I was able to do a workaround..
