Hi all!
I need to read some information that is available through a web service. What do I do in TM1 to access this information and save in a cube?
Thanks a lot!
Renata
TM1 connecting to a Web Service
Re: TM1 connecting to a Web Service
Renata,
If you have 10.2, you can use the REST API
https://www.ibm.com/developerworks/comm ... I%2010.2.2
EDIT: Oh...oops...I read that the wrong direction.
Are you trying to get data into TM1 from a web service via a TI script?
Hi blackhawk!
Yes, via TI script. Is it possible? If not, should I use only the REST API?
Thank you!
Thank you!
- Harvey
- Version: TM1 8.3 onwards
- Excel Version: 2003 onwards
TM1 does not have any built in functionality to connect to external web services.
If you would like to import data from a web source, you would need to write a custom executable or script to do the work.
Many approaches are possible. For instance, the program/script might poll the web service periodically and write the data to the file system. You could pick this up with a scheduled chore that imports the local file into a TM1 cube. Alternatively, you might opt to write executable application that gets the data, then uses the TM1 API to fire off a TI process to import it.
How you approach it really depends on the scenario, connectivity and nature of the data.
Harvey wrote:..., then uses the TM1 API to fire off a TI process to import it.
Or TM1runti.exe can be used.
Actually, the way I would consider doing it is create a Java extension to pull the data from a web service and then write it to a file. The java extensioni could be called from the TI script in the prolog section. Then, the TI processes like normal using this new file.
You can make the GetWSData dumb, in that all it does is take the data from the web service and write it to a CSV or tab delimited file. Then leave it up to the TI process to understand what columns it should load or not load.
Hope that helps.
vWSUrl = 'http://myserver/getdata';
vTempFile = 'filename.tmp';
retVal = ExecuteJavaN( 'com.sample.GetWSData',vWSUrl, vTempFile );
If( retVal > 0 )
ProcessQuit;
EndIf;
DatasourceNameForServer = vTempFile
Hope that helps.
- tianoklein
- Excel Version: 2013
Hi blackhawk,
Did you try this ???
http://tm1server:9510/pmpsvc/services
http://www.tm1forum.com/viewtopic.php?f=3&t=11028
OR
Did you try to create a TI - TM1 SDK JavaExtensions??
http://www.tm1forum.com/viewtopic.php?p=51180
Please let me know if you have succeeded, because I have the same problem and could not find a solution.
OR
