I got the following Memory Error in 9.1 SP2 U3 Build : 9.1.20300.185
4316 WARN 2008-06-18 05:34:50,031 TM1.Server.Memory al_Alloc() outOfMemory Exception <<< MEMORY_TEMP_POOL_EXCEEDED >>> - threadID "4316" - apifunc# "131" - pool# "0" - poolsize "81060608.000000"
Has anyone seen this before please?
thank you
Paolo
Memory Error / Server Crash in 9.1 SP2 U3
- jim wood
- Version: PA 2.0.7
Re: Memory Error / Server Crash in 9.1 SP2 U3
Check your setting for MaximumViewSize in your config file. If you are on windows 32 bit the default is 100MB. You may want to set it to something higher. See if this works,
Shop at Amazon
Shop at Amazon
64 bit server and it has 64GB of RAM
- jim wood
- Version: PA 2.0.7
I would still check your setting in your cfg file. If you have no setting try putting it up to 1GB (1024).
Shop at Amazon
Shop at Amazon
