app_maintenance.bat with CAM Security fails
Posted: Tue Apr 15, 2014 2:03 pm
Dear Forum members,
has any of you already used the app_maintenance.bat tool to perform maintenance tasks for a TM1 Applications app? I would like to import a rights file, but I don't even get that far due to the following error message:
We're using CAM authentication against a Cognos BI 10.1.1 server running on another machine. This works perfectly so far, except for this tool. I've tried both passing the -pwd parameter as well as passing .dat files created by the TM1Crypt.exe tool before.
TM1 version is 10.2 with FP1. The Cognos BI is version 10.1.1, still with FP 1.
I guess the error is not within TM1, but rather withing the Cognos BI server, at least the java error stack may be understood in that way (see stack trace at the bottom of this post).
So have you ever successfully used this tool with CAM security? Which product versions were involved? Do you have sample command lines that definitely worked for you?
Thank you very much!
foogy.
com.ibm.cognos.fpmsvc.exception.FPMSVCException: INVALID_IDENTITY
exitCode=700
foogy.
'com.ibm.cognos.fpmsvc.exception.FPMSVCException: Ungültige Identitätszeichenfolge. :INVALID_IDENTITY'
WHILE [CCLMsg: system text='INVALID_IDENTITY']com.ibm.cognos.pmpsvc.service.api.ServiceCredentialException (root org.apache.axis.AxisFault):
at com.ibm.cognos.pmpsvc.service.impl.PlanningService.checkForSessionException(PlanningService.java:700)
at com.ibm.cognos.pmpsvc.service.impl.PlanningService.logonService(PlanningService.java:245)
at com.ibm.cognos.pmpsvc.ApplicationMaintenance.doLogon(ApplicationMaintenance.java:989)
at com.ibm.cognos.pmpsvc.ApplicationMaintenance.execute(ApplicationMaintenance.java:888)
at com.ibm.cognos.pmpsvc.ApplicationMaintenance.main(ApplicationMaintenance.java:190)
Caused by: com.ibm.cognos.fpmsvc.exception.FPMSVCException: Ungültige Identitätszeichenfolge. :INVALID_IDENTITY
at org.apache.axis.message.SOAPFaultBuilder.createFault(SOAPFaultBuilder.java:222)
at org.apache.axis.message.SOAPFaultBuilder.endElement(SOAPFaultBuilder.java:129)
at org.apache.axis.encoding.DeserializationContext.endElement(DeserializationContext.java:1087)
at org.apache.xerces.parsers.AbstractSAXParser.endElement(Unknown Source)
at org.apache.xerces.impl.XMLNSDocumentScannerImpl.scanEndElement(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$FragmentContentDispatcher.dispatch(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
at org.apache.xerces.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at org.apache.xerces.jaxp.SAXParserImpl.parse(Unknown Source)
at org.apache.axis.encoding.DeserializationContext.parse(DeserializationContext.java:227)
at org.apache.axis.SOAPPart.getAsSOAPEnvelope(SOAPPart.java:698)
at org.apache.axis.Message.getSOAPEnvelope(Message.java:435)
at org.apache.axis.handlers.soap.MustUnderstandChecker.invoke(MustUnderstandChecker.java:62)
at org.apache.axis.client.AxisClient.invoke(AxisClient.java:206)
at org.apache.axis.client.Call.invokeEngine(Call.java:2784)
at org.apache.axis.client.Call.invoke(Call.java:2767)
at org.apache.axis.client.Call.invoke(Call.java:2443)
at org.apache.axis.client.Call.invoke(Call.java:2366)
at org.apache.axis.client.Call.invoke(Call.java:1812)
at com.ibm.cognos.fpmsvc.api.FPMServiceSoapBindingStub.logon(FPMServiceSoapBindingStub.java:1461)
at com.ibm.cognos.pmpsvc.service.impl.PlanningService.logonService(PlanningService.java:239)
... 3 more
