Can anyone please help me out? The TM1 Application server has stopped in our Windows server. We have tried to restart it from both Cognos Configuration and Local services, it starts but then stops. I found the below error message in Cognos Configuration while restarting,
[Start]
[ ERROR ] Using JVM: C:\Program Files (x86)\ibm\cognos\tm1\bin\jre\7.0\bin\j9vm\jvm.dll
BINARY_PATH_NAME : "C:\Program Files (x86)\ibm\cognos\tm1\tomcat\bin\tomcat6.exe" //RS//pmpsvc
The service "pmpsvc" is registered
errorlevel 0 exit 0
keytool error: java.lang.Exception: Certificate not imported, alias <applixca> already exists
keytool error: java.lang.Exception: Certificate not imported, alias <tm1ca_v2> already exists
Updating the service "pmpsvc" ...
errorlevel before exit script 0
Clearing caches ...
Starting the service "pmpsvc" ...
The IBM Cognos TM1 Application Server service is starting.
errorlevel 1 exit 1
The IBM Cognos TM1 Application Server service could not be started.
The service did not report an error.
As the "pmpsvc" service is not running, Cognos Insight and TM1 web is not working. The TM1 version installed is 10.2.2. Can you please suggest what need to be done to fix it (Except reinstalling)? Attached are some error logs from tomcat. Thanks in advance!
