Workflow Failed to Create - "Value" dimension
ashishkmr1
Version: 9.5
Post by ashishkmr1 » Mon Nov 15, 2010 4:37 am
Problem
1. Dimension create fails with error message "Dimension Save Failed".
2. Creation of new workflows or processes in the existing workflows fails with the error message "Workflow creation failed".
Both these issues will come in V9.5 if there is a dimension named "Value" in the model. This will be fixed in V10.1 as per the development team.
IBM Response
Development have come back and it seems this is a known defect that has been targeted for a fix in TM1 v10.1. The problem is that you have a "Value" dimension in the model, and that breaks the rules for the }ElementCaptionsByDimension cube.
There is a workaround for this issue, it is;
- Modify the '}ElementCaptionsByDimension' rule (first line) to display as follows:
['}CaptionMeasures':'Value'] =S:
Ashish
