9.5, Cube Viewer, No data and Autocalc
Post bug reports and the status of reported bugs
Steve Vincent
Version: 10.2.2 FP1
Post by Steve Vincent » Tue Jun 22, 2010 2:57 pm
There appears to be a bug in the 9.5 cube viewer under the following circumstances;
open a view that contains data
suppress zeroes turned ON
automatic recalculate truned ON
alter the view to a selection that has no data
the following error will pop up;
(noerror):error getting subset properties
View then gets corrupted. If you have suppress zero OFF it works fine. Same happens if you manually recalc the view using the button or F9. The error seems to relate to poor error handling in this particular circumstance, as "No Data Available" should be the error message seen.
Production: TM1 64 bit 10.2.2, Windows 2008/2012 Server. Excel 2010, IE11 for t'internet
Steve Vincent
Version: 10.2.2 FP1
Re: 9.5, Cube Viewer, No data and Autocalc
Post by Steve Vincent » Thu Jun 24, 2010 9:13 am
additional to this, although nothign is mentioned in any of the release notes i can find, 9.5.1 fixes this issue. My advice for anyone going to 9.5 is to consider 9.5.1 despite its newness and likelyhood of regression errors.
nitho
Version: 9.5.1
Post by nitho » Mon Jul 12, 2010 10:18 am
Hi Steve,
I also found that if you view have more than 256 column the calculated cells after column 256 will not show corect figurs, but if you slice to Excel the cells will show correct. I have reported the bug to IBM, and they have reproduced it. So I hope it will be fixed in the next version. (I have not had time to check the 9.5.1 version yet.) Maby the problem that you found is related to this one.
Regrads, Nicolaj
